Beta update - Firmware v. 11.2.8 and MOL 3 v. 11.2.32 for Formuler Z11 Series released.
    • Offizieller Beitrag
    BETA Software Update for Formuler Z11 Series devices.
    Firmware Version : 11.2.8 BETA
    MYTVOnline 3 Version : 11.2.32 BETA
    WARNING:
    If you don`t want to test, please wait until official comes out. No Forum support in other threads if beta in use, beta issues should be discussed only in this thread.
    HowTo Install:
    The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much longer than usual, please be patient and let the box finish the install. If necessary reboot later once again.
    Beta Firmware v. 11.2.8 and MOL 3 v. 11.2.32 discussions only in this thread here! Other open threads with Beta issues will be deleted instantly!
    We need to collect data and feedback's on one place, thank you for your understanding.
    Change Log:
    • NEW: Update to Android security patch level August 2023
    • NEW: Formuler Help Center app. Watch tutorial videos and read support articles about your Formuler device.
    • NEW: Added Surround Sound widget on launcher. Easily check and change the system Surround Sound settings.
    • NEW: Added Mute indicator on launcher. Easily check if mute is enabled or not.
    • Bug fixes, optimizations, and performance enhancements.
    • NEW: Added "Date Added" field in VOD and TV Series pages
    • NEW: Added "Select All" button in the group selection stage in Setup Wizard
    • IMP: Improved support for VOB subtitles
    • IMP: Improved auto-update UX
    • IMP: Improved channel retry UX
    • FIX: "VOD data can't be loaded" error
    • FIX: Wrong time duration displayed in catchup playback
    • FIX: The app is closed when playing catchup on grid EPG
    • FIX: Can't perform refresh on portals that require ID & Password log-in
    • FIX: Series parental lock doesn't work
    • FIX: Some contents play in slow motion
    • FIX: Exception error appears when entering Favorites group
    • FIX: EPG data disappears after playing catchup from Grid EPG
    • FIX: Can hear app sound in background after waking up from standby mode
    Dann bitte erklärt was ganz genau nicht beim EPG stimmt, unsere letzten Tests zeigten das Tivimate unter XC Api ganz genau die gleichen EPG Daten und Zeitraum darstellte wie MOL3 von gleichem Provider. Bitte vergleiche mit Screenshots anzeigen.
    Wenn EPG das einzige wichtige Problem ist dann ändert das Protokoll und benutzt Stalker mit Alternativem EPG, dann habt Ihr 7 Tage EPG.
  • Ich hatte nach dem jetzigen Update plötzlich bei einem meiner beiden Anbieter auch kein EPG mehr.
    Bei mir hat folgendes geholfen:
    Bei meinen Anmeldedaten war im Portal (URL) am Ende noch ein /
    Nach Löschung des Schrägstriches ging es plötzlich.
    Musste jedoch meine gespeicherten Sendelisten neu eingeben.
  • Hi zusammen,
    heute mal die Beta drauf gemacht (Z11 Pro) .
    Bis jetzt läuft alles stabil, :thumbup:
    Werde euch weiter berichten ob es läuft .
    Einmal editiert, zuletzt von Banu (23. November 2023 um 16:22) aus folgendem Grund: Bis jetzt alles ok .
  • Dann bitte erklärt was ganz genau nicht beim EPG stimmt, unsere letzten Tests zeigten das Tivimate unter XC Api ganz genau die gleichen EPG Daten und Zeitraum darstellte wie MOL3 von gleichem Provider. Bitte vergleiche mit Screenshots anzeigen.
    Hey, ich benutze Stalker mit MAC-ID und würde gerne wissen welche alternativen EPG ich eintragen kann ? Gibt es freie URL's ??
    Bei Stalker geht das nicht aber es gibt in den Einstellungen des Stalker Portals die Auswahl zwischen Standard und Alternativ EPG. Im falle von Stalker ist es am besten dann auch den Alternativ EPG auszuwählen und neu ziehen zu lassen.
    Beziehst sich deine Frage auf das einpflegen eines dritten EPG (von anderem Anbieter als den von deinem Provider) mit extra URL, dann kann dies unter einer M3U Playliste eingetragen werden.
