- Offizieller Beitrag
Software Update for Formuler Z11 Series devices.
Firmware Version : 11.2.6
MYTVOnline 3 Version : 11.2.14
Important:
Please use backup function first and save MOL3 data on USB stick, before you start with the update.
- FIX: System-wide media playback stutters when certain USB devices are plugged into the device
- FIX: UI display issue in "F1 TV" app
- FIX: Can't re-connect to saved WPA3 WLAN network
- IMP: HDMI stability
- IMP: Hauppauge USB tuner driver optimization
- IMP: Quicker Bluetooth scanning
- NEW: Alternate EPG Mode for Stalker. Access from Portal Edit menu. (MOL3 Menu -> Content Manager -> Content Sources -> Your Stalker Portal -> EPG Mode -> Change from Default to Alternate and set
offset ). - FIX: Can't play some AVI files
- FIX: "MediaCodecVideoDecoderException" error
- FIX: Unexpected cursor movement in VOD menu
- FIX: EPG offset values not working as intended
- FIX: Playback stops when BT audio devices are connected
- FIX: 404 error occurs sometimes when zapping
- FIX: Wrong channel description displayed in Single EPG
- FIX: Can't play certain content with VLC Player
- IMP: Favorite channels disappear sometimes
- IMP: Improved robustness for recording files
- IMP: System screensaver can now activate when media is paused
- IMP: Resume playback not working on some portals
- IMP: Universal Search display improvements
- IMP: Metadata display speed improved
- IMP: Improved Portuguese (Portugal) translation
- Bug fixes, optimizations, and performance enhancements.
