- Offizieller Beitrag
BETA Software Update for Formuler Z11 Series devices.
Firmware Version : 11.2.2 BETA HOTFIX
MYTVOnline 3 Version : 11.2.2 BETA HOTFIX
WARNING:
If serious errors occur, please do factory reset. Please note, this is Big major update! Factory reset is from my side recommended if some parts doesn`t work like they should.
HowTo Install:
BETA FW- 11.2.2 and MOL3. 11.2.2 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
Firmware Version : 11.2.2 HOTFIX BETA
- FIX: Systemwide media playback stutters when certain USB devices are plugged into the device
- FIX: UI display issue in "F1 TV" app
- FIX: Can't re-connect to saved WPA3 WLAN network
- IMP: Hauppauge USB tuner driver optimization
MYTVOnline 3 Version : 11.2.2 HOTFIX BETA
- FIX: "MediaCodecVideoDecoderException" error
- FIX: Unexpected cursor movement in VOD menu
- FIX: EPG offset values not working as intended
- FIX: Playback stops when BT audio devices are connected
- FIX: 404 error occurs sometimes when zapping
- IMP: System screensaver can now activate when media is paused
- IMP: Resume playback not working on some portals
- IMP: Universal Search display improvements
- IMP: Metadata display speed improved
