Formuler Remote App Software Update 1.1.9 BT1 / IR1 Z Boxes
  • Formuler Remote App Software Update 1.1.9 for BT1 / IR1 on Z Boxes.
    Version : 1.1.9
    Change log:
    • ADD: [BT1] TV IR Database update
    • ADD: Help (Remote guide)
    • ADD: Hotkey > Color key setting option
    • ADD: Setup Hotkeys > Backspace key
    • ADD: Setup Hotkeys > Tab key
    • ADD: [BT1] Setup TV IR Control > SANYO TV code
    • IMP: [BT1] Setup TV IR Control > Add Alternate Code up to #5
    • IMP: Hotkey > changed the mouse cursor image
      • Can be moved to the edge
    New for Z Boxes in this version: If you set hotkey for "VFormat" and hold the button longer than 2sec. you can now open the PQ Settings (Picture Settings).
